01 block 06 heads
cncnimal
tulsa
New to thread, I have an 06 with rod knock, or other possible top end issues. I found an 01 short block can i bolt up all my 06 stuff to the 01 block and get on with my life.
cammerfe
Metro Detroit
A rod knock isn't a 'top-end issue'. That being said, there are detail differences between '01 & '06. The '06 has variable valve timing that's run by oil pressure. Using an '01 short-block will necessitate the shutting off of the timing feature or supplying oil (externally?) to make the timing work. It could be done if you're 'handy' enough but you may well be better off to find a block that matches the upper end.
KS
