00 Lincoln LS with a 02 Jag S Type steering wheel?
JustALs
Canada
hey guys trying to fix my ls down to adding cats up to the main timing chains and new windshield.. I need a steering wheel and I was looking at this jag s type 2002 one and looks to be the same as the ls but with two bumps on the padding, does anyone know if it fits on a 00 ls thanks
Jag Steering wheel.
There you go, it does fit if you use a Jaguar airbag also, however you have to trim a bit from the inside of the steering wheel to make it fit, not visible once it is on. Also the buttons are opposite side on the Jag, so you have to use the Lincoln buttons.
I have a Jag steering wheel. The most important thing is to make sure that the wheel has the right hole opening to match the LS steering column. At some point they changed it from multiple teeth to a hex hole like this.
