00 Lincoln LS V8-check engine light-code p1405
rlemay2
Attleboro
I have a 2000 lincoln ls V8 and the other day the check engine light came on. there is 100,000 miles on it, but has been running a little shady recently. I took it to autozone 2day and i was just hoping for a common missfire and an easy repair. The code came up P1405..i cant find anything online about it, and id like to repair ASAP before it leads to more problems...ne help will be greatly appreciated.
not really sure exactly the engine is just beensounding like :q:q:q:q...it actually sounds like whenyou put cards in ur bicycle tire lol...but neways the transmission has been kinda slippin, drops into the gears hard other than that pretty much okay...i was just suprised when the check engine light came on and i have no idea what that code means
I came across a list the other day in a download someone recommended to me.
I looked it up and found this....P1405 DPFE Sensor Upstream Hose Off Or Plugged.
I wounder if someone can take the list and post it up on the site somewhere.
P1405 Differential Pressure Feedback Sensor Upstream Hose Off Or Plugged
the DPFE is a little plastic module on the firewall behind the engine on the passenger side. It has on electrical connector and two little rubber hose coming from it to the EGR tube (which come off the passenger side exhaust manifuild to the EGR valve on the intake).
Its job it to measure the pressure build up or drop in the EGR tube - which tells the PCM that the EGR valve is working properly.
Check to see if one of the little hoses is off, plugged, or cracked.
