04 LS V8 No cruise control after PCM replacement
Parker B39
California
Hello again, recently I had to replace the PCM in my 04 LS V8 after it died on me one day. After sorting all that out I find out that my cruise control is no longer working, not lighting up at all and no related codes from what I can tell.
Just wondering if anyone else has had a similar issue or has any idea how to fix this.
Any help is appreciated,
Thanks.
Probably the clockspring and just an unlucky break that it stopped working after the pcm replacement. Do all the steering wheel buttons work?
All of the other steering wheel buttons and horn work fine, so I’m thinking it’s not the clock spring.
What are you using for a scanner? It might not be able to see all the codes.
Do you have a shop manual? Cheap to get on EBay if you don't have one.
I’m using a laptop with FORScan or a smaller Bluetooth scanner depending on the day. I know I can see all the codes that show up, I’ll check again as soon as I can drive it more and see if anything comes up.
As for the service manuals I have the full set with the exception of the emissions manual.
