dunndarryn
Does anyone know how to recharge the a/c on the LS? I'm new to the car guy world & I'm trying to figure everything out so I can be a "do it yourself" kinda guy. Thanks!
The only bad is if it is a 8 cyl. the ports are on compressor which you acces from underneath the car.
They haven't made a damn thing easy on this car...
If it's just low (not empty), you can do it with a set of pressure gauges (you have to monitor both the low and the high side) and the correct pressure temperature chart for your car. (I can supply for the LS.) However, you can't really justify the cost of the correct setup for just one or two cars that need to be topped off every few years.
Would you pm me the temp chart for a 2000 v8? I need to charge mine due to the engine swap. Forgot to ask them to do it.
Thanks.
Note that these are gen I charts. The pressures for gen II are different. Also, the engine is to be ran at 1500 RPM the whole time while checking pressures and adding refrigerant.
...Would not bleeding the system correctly make the a/c not blow very cold?...
Ok thank you (check that off the list)No, it wouldn't.
But if they did work on the primary chains they would have had to pull the front cover and most likely the AC compressor, maybe not charging it correctly.
