Hello all!  First post here.  Lurking this forum has lead me to picking up a 2000 LS V8 with 149K miles.  I think I got a faily good deal, $3700.  however, in retrospect it may not have been such a great deal.
First issue, rough idle and a knocking in the front of the driver side engine. After research sounds like a tensioner. The previous owner said he replaced the coils and plugs and the O2 sensor trying to fix the rough idle. I have torn the valve cover off and this is what I see:
Full Size Image
I have ordered a metal tensioner as a replacement. I have a couple of questions however, do I need a valve cover gasket set? I didn't see any oil in the plug cylinders. Would this issue cause the check engine light to come on?
Before I parked the car and tore the top off when driving around 50 MPH and I floor it so see what the car has, it would downshift and accelerate, but the check engine light would flash at that point. From what I have read this is a coil pack issue?
I replaced the fuel filter last weekend. It was the original filter as near as I could tell. Prior to changing the fuel filter every 10 to 15 cranks the care wouldn't start. It would crank but wouldn't start. If I waited a few seconds and tried again it would work fine. Since changing the filter it appears to have rectified the issue. Am I fooling myself here? Should I go ahead and replace the fuel pump or at least prepare myself for that?
I know eventually I will need to tear in to the transmission. It clunks in to reverse or drive if I don't give it a moment to build up pressure and kick in to gear. As near as I can tell the car has never had a transmission flush and is using the original gunky fluid.
I can also tell I will eventually need to replace the ball joints on the drivers side. I haven't looked at the passenger side.
The passenger door pocket had a little standing water in it. I think this is the sun roof drain rail issue?
Quite frankly the deal that I got on the car isn't looking like a deal so much anymore... Albiet, I am only around $600 or $800 in repairs if I continue to do them myself... Good thing I only drive about 5K miles a year! I can actually afford the time to fix the car. I can drive the wife's car if/when I need until I get this car on its feet.
The only mods I plan are a full detail including inside and out, engine compartment, everything. (not really a mod, but a significant time investment...) The car has horrible swirl marks all over it. It is pearl white. It has a few dents and dings, but I don't plan to fix them. It has a rock chips here an there. Nothing too bad.
After that I plan to upgrade the stereo to something with bluetooth and sat radio. I have a pioneer double din in mind. I will also add a component set up front with custom fiberglass kickpanels and some midbass drivers in the door running from a Massive Audio NX4 mounted in the trunk. Even though I don't drive a lot I do need bluetooth in my "mobile office" and I have the other gear (speakers and amps) so I figured I might as well tweak it out.
I want to clean the headlights and am on the fence about replacing them versus a kit to clean them. Any opinions? I have looked a the Pinnacle system at autogeeks.net. I plan to pick up the supplies to the detail the car from there anyway and since I am spending the money might as well pick up the headlight kit from Pinnacle.
Last I will probably tint the windows and be done with any mods.
I plan to keep the car about a year, maybe two, maybe longer if it suits me. My typical cycle is pick up a car at auction (my FiL is a car dealer) and drive it for a year. Since I put so few miles on a car this has worked in my favor typically. Last car was a 2004 BMW 325i with 116K miles on it when I sold it. I put about 5600 miles on it. Basically spent $600 to drive it a year. The reason I got rid of the car was two fold, smoking when it started and need extra room for a carseat for my son. The smoking could be fixed but the space couldn't. I have always like the LS and thought I might try that. I bought one in cash with the money from the BMW and set back around $1500 to $2000 for the headunit and repairs. Granted the headunit will take a back seat if it needs more repairs...
Edit:
Forgot to add:
I need to find a new rearview mirror, the current one looks like the auto dim is smeared over 3/4 of the surface. Can't really use the thing as is...
I need a driver sunvisor clip. Current one is broken.
	Full Size Image
Edit:
Forgot to add:
