2005 Turbo LS
Doesn't seem like the turbo is really spooling much and yeah it's an old video.
Ive seen it before, I think if you check that guys other videos you find that it is a v6 too
Id rather have a supercharged 4.6 LS....but :q:q:q:qin ford decided to use a different motor.
not a good enough one!
they should have started with a proper motor and designed the chassis around it.
Agreed, I read on here a while ago that a 5.0 motor will fit in the engine bay. The only problem is that it can't be put in from the bottom like would on the assembly line correct?
Now that woulda been radical!
