thehamm99
Okay, here it is.
(Yes, I searched quite a bit, but the search function results in very broad findings...basically come up with the same posts no matter what word I search).
So here's the issue: I have an idle that fluctuates, from 650-1000 when engine really cold, from 750-900 or so when engine is warm. Also, it sounds and feels (upon acceleration, and at consistent speeds, highway speeds, etc.) like there is a slight miss, or maybe just is running slightly rough.
Here's what I've done:
Spark plugs: replaced, with ap 764
Boots: replaced with new
Coil packs: did not replace, but lifted each one from plug with engine running, and they seem to be good.
Fuel filter: replaced - didn't seem clogged anyway
PCV valve: replaced - seemed fine anyway
Air filter: replaced - didn't seem too dirty
MAF - cleaned thoroughly with appropriate spray and reattached
EGR Valve - cleaned with spray and reattached
IACV - tried to use one I grabbed at pick n pull, same issue persisted, so I cleaned the original with spray and replaced it as well as the gasket.
Did a seafoam treatment through pcv line. It smoked heavily for a couple minutes at high rev, but that was it.
I noticed if I sit in park and rev it to just over 4000 rpm, it sounds like a very minor backfire...which doesn't happen if I only rev to 2000 or 3000 rpm.
A couple months back it stalled out twice when pulling up to curbs at very low rpm...but that problem has not persisted. Maybe something I replaced/cleaned fixed that part of it.
*No smoke, *no rotten eggs smell, *no check engine light, *no heavy hesitation, *no loss of mpg, *no dying out, still performs well.
I'd say it feels like the engine is performing at about 80%, and sounds accordingly.
So I'm wondering? IACV, EGR valve solenoid, Throttle position sensor? Cat converter? I'm trying to avoid just throwing money at different parts unless I have to.
If I can get a hold of an obd II scanner, will it pull any codes without check engine light?
I'm sure I left something out, apologies in advance.
Any help is very greatly appreciated.
Thanks.
Thanks.
