Pcv valve 3.0
msgtusmc
CHESAPEAKE
Does anyone know where this valve is located? I have replaced many in the last 50 yrs. and never had a problem locating it! Thanks for the help!
2000 Lincoln LS Base 3.0 V6 Auto 87k miles
You aware of old part called a "turkey pan" its locate there in middle of engine under intake. Get a NEW hose that goes to it while your there. There is NO turkey pan but you said you where old school like me and this would help.
remove the intake manifold, you will see the fuel lines and to the injectors, its under the fuel lines. follow the thickest and hard plastic hose from the manifold to a metal tube, and there it is
Thanks! Raining now. fair weather mechanic! Had the ***** manifold off 6 times this year, getting good @ it!
