Icarus
The battery light came on the other day, pulled into parking lot and it was dead. Got a boost and it was enough to get home, though when the caa guy tested it then, he said the alt and battery were fine?!
I took the batt and alt out and had them tested at two different stores, both said the battery was no good, but only one store had the right plug-in to test the alt and it tested fine 2x there.
Ok, so I figure it is the battery and get a new one. Install it, it runs fine for about 10 min then the battery light comes on again! I use my meter on it, and it's not charging, but draining (12.16V with heater etc on.)
I'm going to pull the alt off again tomorrow and take it to the rebuilders and see what fun he has, as this will make 5-6 alts in 3-4 years or so, and third battery...
Any ideas on what might be causing this would be great, tested for draw and it's fine each time... each part tests fine then suddenly goes dead after days or weeks it looks like...
