nelliott500
I did a good bit of searching, but I keep finding the same threads over and over again. They all mention the trans fluid additive, but no info on it.
I bought plenty of Mercon V today to do a fluid swap next weekend, but I wasn't aware of the additive. Is this something I need to get? I'm just assuming the solenoid pack has never been changed, so should I just get the additive no matter what? I'd think there's no harm in it if the solenoid pack is the new or old style.
And what's the deal with the TSB on the solenoid? Is there a way to verify that a car has had the work done from the TSB?
The car shifts real smooth through all the gears. However, going from reverse to drive, it does hang for a second or two and shifts a little hard. Neutral to drive is quicker and not harsh.
EDIT: Also, how much fluid is typically removed when draining the trans from the drain plug?
