JackRabbitStorm
2001 Lincoln LS
I ran some RCA Cables from my head unit the other day. I also pulled out wiring and an module the previous owner had hooked up for their head unit, no other wires were connected to it, module said Alpine on it. Did not mess with any other wiring.
Since then, the dash lights do not work, but the message center lights work, the CEL/ABS lights work. The light for the gear shift do not work, nor do the AC lights, but all HVAC controls do still work. My AdvanceTrak control button does not light up, nor does it allow me to to switch the Traction Control on or off.
All fuses in the passenger cabin compartment are okay, and none of the other fuses seem like they would control these lights, but those are a lot harder to get to to check them.
Checked dimmer switch, its not that.
Headlights, turning lamps, fogs, heat all works, just the dashlights and the traction control don't. Map lights and all that work as well.
What should I be checking next? I am at a loss
