Sapperfire
Baby Powder the block, look for the new wet spot
Kinda like dating a fat chick
If motor is coming out throw walmart oil in it fire it up and see where its coming out. All those spots you mentioned can leak.
Blah, too late to do that now. Come home from work the other day and find the engine is already out.Guess I will just have to look for leaks when the engine goes back in. Whenever I did change the filter though, there was a drop of oil coming down from the oil pressure sensor. Maybe it finally gave away, but I am stripping her down right now, and it's about to be on an engine stand, so I will take the oil pan off and look at the damage. That crank is mighty hard to turn also, so pretty sure it's a bearing.
What year is your engine?
This is an interference motor if the timing jumped that much you probably have bent valves
I would at least pull a head off and check.
