A few updates as I spend the last 4 hours working on wiring.
1. KnuKonceptz wire seems to be pretty damn good stuff. Very thick, very flexible and fairly easy to work with. I haven't had power to anything yet which is obviously the true test but quality seems great.
2. KnuKonceptz set screws are a total pain in the A$$. First of all, the 4 gauge set screws were too large to fit into the power and ground slots on my amp so I had to grind them down (luckily I used my dad's bench grinder so it only took a minute and it looks clean). They are very beefy and I get that they are probably for much higher powered systems than mine, but a couple millimeters off the sides and the ends and it would have fit perfect. I'm also a little concerned that since they are so bulky, the ground and power are very close. They're secure so I don't see them moving or ever touching, but I could probably only fit the width of a car key/piece of cardboard between them if that makes sense. Also, the 0 gauge set screw is wayyyyy too small for their 0 gauge wire - took me forever to get the wire into the set screw.
3. The KnuKonceptz dist block looks to be great quality. I like how the fuses work and I also really like their "compression fittings." It was super easy to set up.
4. I got some infinity 6x9 speakers for the deck and I ran into another problem. I couldn't just mount them on the rear as the bars that run from the magnet to the cone were out to far so the speaker wouldn't sit flush. The bars (I don't know what they're called) hit the sides of the openings and prevented the speaker from falling into place. I needed to raise the speaker around half an inch. Luckily dad was home (I was using his garage) so he cut me some "speaker spacers" which worked great (He has his own shop so it only took him a couple minutes to make some nice spacers). Unfortunately, my stupid as$ may have screwed up a speaker. I attempted to use the screws from the original stock subs and I wasn't paying close enough attention/couldn't see it very well/it was getting late and when I tightened it down, it caught the rubber surround and smooshed it. I backed the screw out and the surround looks a little damaged but I don't think it's punctured. It just annoyed me because I was purposely going very slow and making sure everything was perfect and then I did that. Any thoughts on this? I don't think it's punctured but would a small dab of good rubber silicone help/give me peace of mind. I attached a couple pics and it actually looks quite a bit worse in person - it was dark and my camera phone sucks.
Tomorrow I'm hoping my second amp shows up in the mail. If it doesn't, is it safe to cap the end of the power wire which is supposed to run to that amp and use the car? I don't want to have to remove the wire from the dist block and go through that again.
Also, I'll take some pics of how I ran the wires/mounted the amps/mounted the deck speakers/etc.
