tynekia33
i have a 2003 lincoln ls v8 wit 162,000 miles. when u first start the car when its cold out it will not start but when its warm its starts fine with no check engine light on at all...when the check engine like does come on it shows a code of p0606 and says etc safe fail mode.. i replace battery i changed fuel filter i changed engine coolant sensor also changed crankshaft sensor and it still does not start when it cold. can someone please help me if you have had this problem
