adjustable links
oldhead
Brick City
does anybody knew the measurements of the bushing at the wheel end of the adjustable link.
Also has anyone tried to replace just the bushing with a poly u type?
Please be specific and give details. Your question is too general. Then we;ll try to help!
KS
Are you talking about the joint at the end of the toe-link, at the wheel side? That is not just a bushing. If you replaced it [somehow] with a bushing, you'd never be able to keep a good alignment as the bushing would compress under the variable load on it.
Yes those are the one I am talking about.
So these could not made to work.
http://www.energysuspensionparts.com/Energy-Suspension-Universal-Link-Flange-Type-Bushings.asp
The problem is that the connection between the wheel and the toe-link has to move in two dimensions, not just one. In addition to the rotate left and right motion, there is also a tilt up and down motion. I haven't pulled one apart, but I suspect that the inner sleeve is somewhat ball shaped in the middle.
