ok 2004 LS. When i try to use my windsheild wipers here is what happens. In off mode of course they are off. When i select auto mode, they cycle once and do nothing...hence my last post about replacing my rain sensor. But then as i go to select ANY of the intermittent settings i get nothing...or on the very random occasion i get always on LOW for a few seconds. If i select Always on LOW or HIGH, those both work. So basically i would like to have intermittent controll of the wipers. Would replacing my rain sensor fix that as well even though it isn't an auto setting, or is it my muti-function switch that needs to be replaced? or even as simple as a wiper delay relay (not sure if the system is set up to run off of a relay, but ive seen it before)
