Dieselmechanic
99 Conti here, 68,000 miles.
Drives perfectly fine, then will die and not restart. Fuel pump is shutting off on me.
No codes thrown (other than a airbag code 36).
Previous owner had the same problem, the stealership replaced the pigtail to the Crank Position Sensor. Errors fromt eh CPS can cause it to shut off the fuel pump, correct?
Just kinda new to the Ford thing.
 How would you guys go about diagnosing this?
Thanks!
Thanks!
