2003 Mach 1 Transmission
its a 4r75w. like it matters though.
should drop into a 98, repin or connector swap for 93-97.
Could be just nonsense but I heard those transmissions were hard to make shift right when not in a mach 1
What about the trans from a newer stang? A 5/6-speed auto would be nice in our cars.
And don't get me going about paddle shifters.
Are you talking about the 6 speed? You afraid of no lock up? You think you would even be able to tell in any way from MPG to cruzing?
there has to be a difference in mpg. engine power is being lost in converter slip.
the overdrive on that thing also isn't even as good as a 4r. close, but why isn't it? i has 2 more gears than our trans.
if i'm gonna put up 7 grand, i would like to have lock up.
i would like something like the 6R from the new mustang. killer 4.17 first gear and a .69 od to boot. with a locking TC.
If you are making any real high HP you are NOT looking to gain 1-2 more MPG. Cuz your not going to have it to begin with. Not saying its cheap just wanted to show there is stand alone 6 speed auto trans out there. A good conv you can get slip down as low as 3%. Plus you dont have to worry about clutches in your converter. I have a Lentech street term non lockup AOD in my street stang no problems.
i understand, but i guess what i'm seeing about that 6 speed just doesn't work for me.
but your right. i didn't know that was even an option.
LOL 7200 does not work for me either!! But 7200 is the whole kit trans,bellhousing, flexplate ,shifter, standalone, cooler and fluid. But no converter!! add 750 most likely.
