hite337
Hite Performance
Ok, after multiple people have PM'd me requesting a write up on my electric cooling fan conversion and hydraulic pump delete on my 1st gen, here it is.
I didnt take step-by-step pics but here's the info as I remember. you will need to purchase a Flex-a-Lite 180 or 188 cooling fan and a 100" x 13/16" multi rib v-belt. removing the hydraulic pump is a pain in the a$$ so dont say you werent warned.
Fan Removal
1. remove intake tube
2. remove radiator shroud/cover
3. remove upper radiator hose (good time to replace thermostat, dccv, coolant resevoir, etc at this time since you will need to bleed the cooling system)
4. unbolt the silver AC cannister from the fan shroud
5. unbolt the aux heater pump from the fan shroud
6. cut the lines going to the hydraulic unit on the fan. these will be full of fluid so drain them into an oil pan
7.unbolt and remove the fan shroud. i believe there are 2 bolts towards the top of the shroud and 2 bolts about halfway down, its tough to pull the shroud up and out of the engine compartment because the brackets on the bottom are big. take your time and dont put a hole in the radiator.
Hydraulic Pump Removal (the fun part...lol)
1. jack up the passenger side front of the car and support with jackstands.
2. remove the alternator. 1 wire harness, the battery wire, and 2 bolts. it takes some manuvering to get it out once its loose but it will come out.
3. Remove the hydraulic pump (SOB). remove the electrical connector. i couldnt remove the smaller steel line on top of the hydraulic unit so i just broke it off. there is a bolt behind this line, it is the worst one to get to. i used a 10mm 3/8" drive socket with a knuckle/swivel and a few extensions. remove the other 3 bolts and the pump will come out the same way the alternator did.
4. remove the hydraulic fan pump resevoir.
5. plug the hoses going to the cooling coil that is located between your radiator coil and the AC coil.
6. reinstall the alternator
7. install the new shorter new belt in the same way as the old belt. the upper idler pulley is smooth and the ribbed side of the belt will ride on the pulley. i'm not 100% sure how this will effect the belt life but mine is doing good so far. the shorter belt is a 100" x 13/16" 6rib v-belt.
The fan i purchased was a Flex-a-Lite 180 electric fan. the 180 comes with the temperature controls to turn the fan on and off automatically with your radiator temp. the 188 is the same fan but without controls. i still had overheating issues using the temp controller, i never could get it adjusted right so i just wired it to come on when the key is on and removed the temp controller. it works just fine. the 188 is also cheaper without controls. the fan comes with installation instructions that will tell you how to install and wire it and aluminum mounting brackets that are easy to bend to the shape you need. you will need to make a custom bracket if you want to bolt the ac cannister to the new fan shroud. you also need to mount the aux heater pump to the new fan shroud with a screw or bolt.
After you install the fan, put the upper radiator hose back on and follow the fill and bleeding procedure for the coolant system.
The Flex-a-Lite fan is about as loud as the stock hydraulic fan on high. it cools my Ls perfectly, i sat in gridlock for 45 minutes on a 105 degree day and no overheating issues.
I also have not upgraded my alternator but i plan to eventually. its my understanding that the hydraulic pump was used because the alternator couldnt support the load of an electric cooling fan. i have not noticed any problems with this but i dont have a 1000 watt audio system either so i would suggest upgrading the alternator if you have alot of aftermarket electronics.
i also intalled a toggle switch to turn my fan off manually. i did this for the drag strip, i turn it off as soon as i stage and turn it back on as soon as i hit the return road. thats good for 50hp i'm sure...lol
i hope this has answered everyones questions about the hydraulic cooling fan setups on the first gen. replacing the hydraulic fan this way is cheaper than replacing almost any one part of the hydraulic system alone. it cost me about $320 total.
Fan Removal
