Here's the how-to.
http://www.markviii.org/LOD2/rear_hub.htm
step 12 says
Remove the 2 lower hub assembly bolts by using the t-50 Torx bit, the ratchet, and the big Crescent Wrench. Be careful of the wahsers, because they have to go back in the same spot as they came from. They go between the hub assembly rubber bushings and the lower connection points for the hub assembly.
How do I get that nut out? The shaft is in the way.
BTW: I have both back tires off the ground. (front hub nut is off)
Take a look at the pics:
step 12 says
