Farking Bastage
I've already combed through the stickies and this doesn't seem to fit the common DCCV issue described therein.
The temperature control on my '03 LS has gone a bit wonky, and I'd like to get some ideas on where to start.
Basically, if you set it on a middle of the range temperature ( really annoying on defrost) it will either go full cold or full hot. However, it is equal on both sides of the system( haven't really tested putting one side on hot and one side on cold). I'll kick the defrost on in the morning at, say 72 with an ambient air temperature of around 80 and she blows full on cold. If I start adjusting it up, it will continue to blow full on cold until I hit the top range of the control at 90, then it blows full on hot. This behavior is also duplicated if I start it on hot. I can move the temperature down and it continues to blow hot until I hit the bottom range of 60 then it goes full on cold.
Basically, I have no mid-range in climate control anymore.
Could this possibly be:
A sensor of some sort?
Cabin air filter?
Low on coolant, but not low enough to totally freeze up the evaporator?
I appreciate any ideas on this.
Thanks
Cabin air filter?
Thanks
