Travis2000LS
So some of you have kept up with the story..
Well turns out the Used tranny from LKQ was bad.. a member on here came and looked at it I thought I gave him a good deal. 3k the way it sits.. Well bank would onl give him 2.5 and I couldnt take it due to I bought the car for more.. Anyways.
Luckly there is a warranty on the used tranny.. Downfall is that Since I bought the tranny for 600 and if there is one for 800 then I have to pay the 200$ difference :,(
So Ive decided I might as well Go ahead spend the extra money to get another used tranny from LKQ and hopefully this time itll be good..
once i get the tranny in and everything is right .. bye bye lincoln :,(
Also I noticed alot of problem my car had before such as like rough feeling when you have a cold start and like almost a knock noise or tap noise when you use to get on it when the old tranny was in.. Is no longer there? So meaning all this time It wasnt the Secondary timing chain it was the old tranny making all the vibration and racket when it was cold..
SO For now im driving the LS with a F'ed up tranny that randomly shoots out of 5th gear, smells like transmission fluid after you get done driving it, has a noise coming from the bell housing due to torque converter being bad and pops into neutral sometimes when you slow down and have to give it gas to pop back into 1st.. Lovley..
Anyways yep thats the update..
