my chargim system came on too, but it sometimes goes away when i rev. it might be the alternator, the reading from the multimeter is good but not estable. i got my alternator fixed once like 10 months ago so now im looking to buy a new one
Hey, jdmans101
Did you end up replacing the alt, and did that fix your problem?
I'm working on a very similar problem with my gen1.
Thanks!
yes I did replace it and haven't had the light come on since, please please make sure you get one from ford, i know its a little expensive but its the only one that works right with this car, dont even consider getting one from auto zone.
...VOLTAGE MEASUREMENTS (measured via DMM at the cigar lighter)
- With the car off, I meaure 12.6 volts
- With the car started, I measure 14.1 volts at all times (idle, or revving to 2500 rpm).
- Voltage is constant with or without accessories loading the system. It's the same when I first start the car, during my commute, and when I arrive at home
- Voltage is always the same, even if the check charging system warning is on or off
RESISTANCE MEASUREMENTS (measured via DMM at the cigar lighter)
- Generally I don't get a resistance measurement, but at times, with the engine running, I measure 12.5 MegaOhms
I'm hoping someone like joegr can see some hints to confirm or disprove the working hypothesis that the alternator is in the very early stages of failure.
Here are my observations regarding my "check charging system" issue.
hmm, mine varies when the car is just at idle. Sometimes it will sit at 14 but then it will slowly drop to low 12's or low 13's until I hit the gas and then it will jump back to 14. Wonder if that is normal... also notice that the lights kinda dim when it get low like that until I hit the gas. Just replaced the alt so wonder If I got a bad one.
The check charging system message can be triggered if the PCM detects that the alternator is working (or seems to be working) harder than it should be to maintain voltage, even if the correct voltage is being maintained. (Basically, the PWM power to the rotor field winding is maxing out.)
Resistance measurements across a power source are completely invalid and so the readings that you get are meaningless. There are ways to measure the series resistance of a power source, but this is not how. You are lucky that attempting this didn't damage your meter.
I agree that the alternator is likely headed for failure. It may be worn out brushes as that is the most common reason for failure, but your symptoms aren't completely typical of that.
- The autolamp issue appears to be that the daylight sensor has failed, so it is always indicating that it's night time. They don't guarantee that will fix the issue, but are pretty confident. Go figure, this will cost $300. I'll rant on this one, because they had this car in with the same issue once before and said they couldn't replicate it - even though the headlights hadn't worked in two months. OK, I feel better now.
That sensor is easy to replace.
http://deneau.info/ls/s6x~us~en~file=s6xh1019.htm~gen~ref.htm
I'm sure you could get it from Max for a lot less than $300.
Oh, great, man. Now I have to consider DIY. Thanks for nothing!
Do you know how to do these two steps?
"Remove the LH and RH windshield side garnish mouldings.
Remove the instrument panel defroster grille."
I hate the thought of breaking some plastic tab and those mouldings flapping around for all eternity.
I've had plastic parts of the interior break all by themselves, but I've yet to break anything while removing or reinstalling it.
Just pull the front door gaskets off, then pull the A-pillars off. You have to pull pretty hard on them, but it will be okay.
I haven't removed the defroster grille before, but it looks simple enough.
what an abortion... my motorcraft reman had issues when they first installed it. It was fine all summer and now that its cold its acting up again. Revving the engine gets the light to go off, and sometimes stay off. I get all kinds of electrical interference buzzing over my speakers randomly (check charging system light not necessarily on). Off to have them replace it under warranty I guess, as long as it does it when I'm there!
Now that you say that, I had the same problem, I had engine noise coming through my speakers and made the car sound like it was supercharged lol really weird. When I got the new alt put in it stoped.
So here's the latest:
The alternator was replaced two days go, and so far no charging system errors. If I don't ever mention it again here, you can assume the problem was fixed!
Thanks to all for your feedback on this issue!
I'm waiting for the new light sensor to come in. I gave the side garnish moldings a tug ,and they popped right off. So if the part is something like $50, I'll DIY it. The only reason I'd let the dealership do it is because they'll credit me the $99 diagnostic fee and they paid for a day of car rental ($40) because I told them I'd have them do the work. But if it will really be $300, even if I give them the $40 back and buy the part for $50 I'll be ahead $110.
The dealership says that they have to re-program the computer when they replace the light sensor. Does that sound right?
