Hi All,
I was just at the dealer getting the crank pulley replaced on my O2 ls . I took a good look at the front suspension that they pointed out to me was close to needing done ie) some play in bearings.
I,m too old to fall for the replacing the whole arm just to get a bearing and luckily I know a fello who has run a front end steering repair facility for years and will press new bearings and replace the arm.
My question is the bearing themselves I can get no problem but I see some available with the old school grease fitting and was wondering if they are any good or should I stick to the german made ones from the fello in New York.
I want to order them as soon as possible so your knowledge and opinions on this would be much appreciated.
Thanks !
Thanks !
