02 3.9L misfire???
streetwise83
Monee
i have an 02 ls 3.9L v8 w/ 95,000 mi. was driving the other day car ran fine got on the highway to merge and it started missing/ surging feeling. after a few minutes check eng. light came on. code was p306 missfire cyl 6 so i changed all the plugs and the coil on #6 cyl. car stills has a mis only seems when engine is warm and at higher speeds. any ideas?? also i found oil in spark plug wells 1.2.3.4.5 the rest were dry i havent done the new valve cover gasket they r on order could the oil in there be causing a mis??
You almost certainly need to replace the other 7 coils, as soon as you replace the VCGs. This includes the dry coils (7 and 8). Time and heat are bigger killers of the coils than just oil.
+1
You can get packs of 8 coils on ebay for a good price. If you dont change the valve cover gaskets you are going to get really good at changing coils one at a time.
