2000 Lincoln LS V8 Sports package 86000 miles
My problem is the emissions portion of the state inspection. The dealer’s emissions computer will not connect to my cars DLC. Therefore it will not pass inspection here. The dealer did have the company that takes care of the shop computer and it is fine (I think it is the state). It also will not connect with my CANOBD2 scanner which does work on my other cars both newer and older.
I have checked all fuses and they are fine. The battery is under three years old and is a Ford battery. The battery is showing green and passes load tests. The alternator is charging above 13.5V. Lighter works, all electronics in the car work. The OBD, DLC connector does have 12V going to it.
Here is a list of odd things happening. None of these things happen at once they just happen when they want to.
Unable to connect to OBD system. Dealer is also unable to connect.
FUEL COMPUTER DATA ERROR (has stayed on all day today)
GEAR SELECT DATA ERROR
CHECK TRACTION CONTROL
Also sometimes when the car starts it gets above idle and shuts off.
Any help is definitely appreciated
