I've had my LS for about 4 months now. I love the car!
But she failed me a few days ago and I don't know what to do.
I was driving home from work, and the car had been driving fine till i got up to about 70 mph. Then the it started to shake, I Flipped it in sst to see what gear was shaking and it was 5th. Got off the freeway and took the back roads home cause the shacking and low (humming?) sound was making me nervous. First stop light drove fine. Second one, my second gear starts to slip to the point where i have to change gears, then the "e" and "check transmission" Came on. I knew this wasn't good just from reading posts on LVC. The next morning I took it to the nearest Lincoln stealership cause I wanted to know the codes. The results were P0735 and P0732 according to the technician. I asked them to preform Electrical, Line pressure, and EPC test. All passed. The technicians conclusion was a "worn case" ( is that the transmission case where everything is housed?) and a Burnt overdrive band.
He suggested refurbed tranny (3675.00 plus tax for them to fix it)
I took it to a different transmission shop they said they could rebuild it, with new brass fittings and fix the issue for 2,500$.
My Question is should I get it rebuilt, try to find a used transmission, or is there another way of going about my problem!?
Excuse my ignorance, and my huge block of text
