Are TBird rear discs interchangeable with the Mark?
LowLincoln
St Pete FL
This may sound retarded but I need to temporarily use the rear driver side disc and pads off the TBird until I can order all new rotors/pads in the coming weeks. The one on the Mark is severely ground down by bare pads and was never changed by the last owner.
I finally got a new roommate moved in today and I will be able to take care of my car finally.
i might be missing something but why don't you just drive the t-bird until you get the new brakes?
Yes, 93+ T-Bird rear disc brakes are the same as the Mark VIII.
Well the Tb has a massive trans fluid leak at the tail shaft and to make things worse, it falls onto the exhaust pipes making some nasty fumes. I don't know what long term effects that could have on my health breathing that stuff in for 70 miles a day but I don't wanns find out.
Thanks man!
understood...i figured there must be something wrong with it but ya just never know on here lately haha
Thanks man!
Check the tailshaft housing bolts, I'm willing to bet they are loose and causing your leak, tightening them up fixes the problem for good 8/10 times, the other 2/10 times the housing gasket needs to be changed along with the bushing and seal. For a free fix it's something to check out.
I wish I could have known that in the beginning. The whole time I was thinking it was the pan gasket as well as a bad joint on the DS because of the vibration. Ended up being those bolts but it was too late. At the end I was in that 2/10.
