stallone 81
im in the market for new rotors and pads amd i was wondering is it worth getting the drilled and slotted rotors or is it better to just get normal rotors ?
No benefits unless you track. In fact, eBay drilled rotors are more prone to cracking and rusting than blanks. They do look nicer though!
Yeah I was going to write that too. Drilled tend to crack more easily than just slotted or blanks.
Are you getting ebay rotors or that rotor pro package?
the flexible brake hose gets extended due to constant fluid pressure against its walls leading to a condition popularly called brake line swelling
These brake hoses made out of stainless steel are tougher and they also are less prone to getting distended due to pressure from the brake fluid. A braided steel brake hose are made of soft materials that are covered by braided steel-strips. It is an improvisation that is also commonly seen in plumbing lines at homes. These braided steel brake lines are extremely efficient and what’s more they also look great. They will give off more predictable brake pedal modulations with a firmer feel. Properly designed big brake kits such as Stoptech big brake kits or Brembo big brake kits, come with these stainless steel hoses for the added benefits.
Well ss line stands for stainless steel (stainless steel braided lines), which wont expand like the oem lines. You get a firmer pedal and they become more efficient when you brake since you don't loose braking power going to expanding the lines.
Edit-
Yep, +1 on the Rotorpros package. I just need to find a set of SS rear lines before installing mine.
