3 small questions
Amish Electrician
Kansas City
Does anyone know what fuse is the cig lighter in a 98 mark? I don't have an owners manual. Also every time i start my car the message center say washer fluid low even though its full anybody know how to fix this or whats causing it? its really annoying. And where is the best place to buy a trac lok 28 or 31 spline? thanks
I'll take a shot at the low washer fluid one. I believe it has a floating magnet or something ,and if it gets stuck it will display low washer fluid. You most likely need to clean it out to get it unstuck, but I have no idea why it would be dirty. You will know if its unstuck when you take it out and shake it and should hear the magnet going up and down, just like the coolant reservoir does. =]
Ill also take a shot at the trac lok. Try americanmuscle.com summitracing.com and ebay.com
I am sure others will chime in.
i will have to check out the washer fluid tank i figured it was a sensor or something..the gears i haven't quite decided yet.
My offer still stands if you want it I even have a good trac loc that I'm holding on to for when I find a set of gears:D
