Pinknuts
Wonder what I'm doing today?
I just don't know...
Ergonomics?pics/info/review? If your successful in not completely destroying the ergonomics of the car I will indulge in the cutting wheel action myself.
$600 for a set of custom springs. Already have eibachs sitting in the garage but I'm not satisfied with the drop and am hesitant to install them as selling used springs is completely different than new ones.
I see the results of that here all the time on Civics. The riders look like little bobble-heads driving around. That will ruin the progression of the spring. Spend the cash and get properly engineered lowering springs.
Same here. You can even look at the car and see it bouncing around like it's got no sway bars or shocks almost. Also hear about the springs bending/breaking the seats since they don't have a smooth face to sit on the perch anymore.
He said he only cut off half a coil on the rears too. I dont see how that will seat correctly and not have the possibility of coming out of the perch causing a huge problem. Given that the eibach springs are already significantly shorter then the OEM's if you cut off to much you will need to find new shorter strut too
