So..... This morning my daughter tried the heated seat; as is her custom. She informed me it didn't work. So I thought I may have left it unplugged the last time I had the seat out. I looked and both plugs are secure. The light for the seat comes on for a second or so, then goes out. The left side works fine. The switch works as I swapped them to eliminate that failure. They use the same fuse, which is fine. Again, the left heat works fine.
Checking the collective wisdom here, would that indicate the heating pad is shorting and needs replacement?
