FASTLLS
Exactly.. As with anything on this car..
So, got the parts in today (except the filter/gasket kit was missing), and before I get them installed, I'm wondering if there is something I can check regarding the pcm to make sure that isn't the issue. I just keep thinking that when swapping the pcm for the used one, if a pin got bent or was corroded or something. Figure that may be worth a check in case I need to return the parts.
