MurderedLS
what would you guys suggest for a tire size, to get no rubbing, for 20'' rims with a +45 offset.
Depends on the rim width, many people use 245/35/20 or 245/30/20.
i use 235/35/20 and i always have the wife and kids in the car and no rub whats so ever
Luckily none of the bends were bad enough to the point were i couldn't bend them back with my special technique.
Are you concerned about the added weight and the negative effects on handeling and brakes?I'm running an 8.5 wide wheel with a 245/35/20 tire. +35 offset on the wheel. No rubbing unless I "really" bottom it out on the interstate at high speeds.
free is good!
I wasn't saying it was bad.. Actually, quite the contrary.. I might have to try that some time..![]()
