I got a code 173 recently and am debating changing mine as the fuel pressure is good and trim values etc are too. I still need to double check the injectors but think that might be my next step...
LSC needs 2 fronts. Am I right?
Ordered them 2 days ago. Car is stumbling pretty badly when cold right now. Has me worried I'll be chasing a pump failure problem. I"m NOT happy.
yes, i changed mine without a code and the car went from 18 mpg highway to 26-27 instantly,i had a rough idle and miss at 2000 rpms but no code, i checked/changed everything,then i did the o2's and bam,it was all good
That's what I need to do to my '96. It's down to 20.2mpg now and it has a rough idle and miss between 2000 and 2500 RPM. Did you replace all four O2's or just the two upstream of the cats?
Myco,
Im curious what Brand and Octane Gas you are using.
I switched brands of gas in early December, and my gas mileage dropped approx 5 mpg. Now, i do not know if thats from the companies switching over to their winter blend, or if its a Brand thing. i always use the highest octane i can find, ie: 91-93.
