Winter Projects anyone?
New mufflers going on tom morning. This is exciting!
Bassani's installed! They are a little louder than magnaflows and sound great. I dont know how you went with resonators though FASTLLS, it seems like if i put resonators on mine they would sound more quiet than magnaflows.
What are you doing with the old mufflers and tips??
The test piece was polished more on the right side which showed hot spots so I will be polishing them more like the left side to make the light more uniform.
And the bottom flat piece will also be illuminated as well.
I actually got the design from the 2011 6-series concept car (Here are to links to photos of that car) It seems so far that the production vehicle will not have this style though and will be continuing to have the current style of ring. http://forum.xcitefun.net/bmw-6-series-coupe-concept-car-wallpapers-2011-t52588.html
I had straight exhaust before and wasn't digging the drone on the highway or the pop on decell.. So I wanted something a bit quieter.. But every time I hit the gas and the converter engages, I can still make people look.. :D
Projects
List in order of necessity---
1. Move '63 F-100 ICB out of garage and tarp for protection. This gives me enough room in the garage to be able to move the car inside for work
2. Re-organize other stored stuff for access.
3. On '02 LS---not necessarily in this order:
A. Finish rear brake upgrade
B. Fabricate rear shock mounts to enable installation of Koni coil-overs front and rear.
C. Finish assembly of four litre AJ27 engine with enhanced parts.
D. Complete and install turbos, oil feed and return, and cold-side piping---fabricate hot-side outlets
a. Fabricate air boxes in rear quarters and install NACA inlets
E. Install enhanced transmission---re-install scatter blanket.
F. Fabricate 'chute mount
G. Extend belly pan
H. Fabricate and install window net mount
I. Wind tunnel tests
J. Set new records in E/F CC and E/BF CC (...and on the eighth day...)
First new year meet is in May.
KS
Mufflers are sold. Black tips went on the new mufflers
True, but I want a louder sound while cruising too. I was scared they would be really loud without resonators but the volume is good, just a bit louder than magnaflows but it has a different tone.
KS
NICE! Things are coming together.
Any chance that meet will out in CA ;)
Land speed racing
All ECTA meets are in Maxton, NC.
KS
Both Muroc and El Mirage are SCTA venues in California. I believe that both run for 1.3 miles. Maxton is 1 mile.
Yeah there are, we just can't get a meet together.lol
I am doing some body work getting ready to shoot new paint in the spring after some girl T-Boned it in September. I am working on some existing rust in my spare time... just pittlin around with it. This is a Toyota, its cheap and reliable to drive
I also have a truck with a bad engine to get running (its an S15) I also have a Mercedes to get running after dropping another engine in it.
