need help my 2002 lincoln ls wont start
powertrain control module and rear electronics module, respectively.
I don't think there's an easy way to check it. I do know another member here had a bad PCM relay causing a no start.
okay thanks would it show up in the dianostest test they run?
Well, that's it for my quick suggestions from a distance. Time for a OBDII scan and close inspection...
okay i just scanned it again and it gave me 4 codes........
P0122-TPS/Pedal Position Sensor A Circuit Low Input
P1121 Manufacturer Control Fuel Air Metering
P0193 Fuel Rail Pressure Sensor Circuit High Input(pending)
P1504 Manf Cntrl Veh.Spd. Idle Speen Control Auxiliary Inputs (pending)
its getting warmer now and i went to try to start my car and it started and ran good for about 2 mins then it shut off again dose anyone have any ideas what could cause that?
For 30 bucks, change out the throttle position sensor. If that doesnt work, change out the Idle Air Control valve for 55 bucks. Then post what happened. It is kinda hard to pinpoint one problem with so many codes at a time.
ive already change the icv and no change . ill change the tps next and see what happens .... this really wierd that it will start and run for a few min when its warm out side but then just shuts off
