oddball
Just some quick tips. I have an '02 with the in-dash 6 disk changer. As is common, the charger is busted - just says "Error" or "CD Error" when trying to load, eject or change any CDs. Bought it that way, hope the previous owners didn't lose any in there!
This radio has the 16 and 20 pin connectors, 20 pin is black/red. There is an additional connector - ~8 pins?
Used the PIE FRDN/PC-POD2 kit, procured from Logjam (http://www.logjamelectronics.com/piefrdnpcpod2.html) along with the CC-iPD adapter so it'll charge my nano.
It was a small leap of faith whether or not it would work considering the internal CD changer. Well, for *my* radio, it does! YMMV.
Steering wheel controls work, sounds great, keeps ipod charged. Couldn't ask for more!
Sorry, no pics of back of radio, and didn't think to write down the part number.
Hints:
1) Cut off connectors, added extensions to the power and ground leads and tied them into the cig lighter. Having miscellaneous small wiring parts on hand is a huge bonus. Did not pull out the soldering iron for this one.
2) Mounted the box onto the tube cross member behind the glove box. Put some door self-adhesive weatherstrip foam on the bottom of the box and zip-tied it in place. Good enough!
3) The 20pin pass through connectors weren't quite the right size. Initial install resulted in lots of problems (steering wheel controls didn't work, turn off when door opened didn't work, ipod box wacky, etc). Fixed with small dabs of hot glue to hold the original connector into the pass-through and the new connector into the radio. Hopefully small enough dabs that I can remove them if needed!
4) While you're in there, replace the foam on the a/c vent tubes. Keep air in the passenger compartment, not behind the dash. I used the same door weatherstrip.
Ooopses:
1) I routed the ipod cable up through the bottom of the console compartment. There's very little clearance between it and the rear seat a/c vents. I figured that out later. Would recommend routing cable through front of compartment. Note that there's barely enough room in there for connector+charging adapter+ipod. Also haven't found an appropriate sized grommet (between 1/2" and 3/8") so the hole is pretty ugly. But it works!
Totally awesome pics in this thread for mounting through the cig lighter trim panel.
Fun facts:
Upper console was squeaking against lower console quite a lot. The old felt was looking pretty bad and was pretty sparse. Cut up an old t-shirt and hot-glued in place around areas where the consoles clipped together and a few others along the edges for good measure. Squeaks are gone!
Difficulty: pay attention and take your time = easy
Benefit: Way Awesome
Hints:
Ooopses:
Fun facts:
