seat fan replacement help wanted
michaelanezinis
Cleveland
Is there anyone out there that has successfully changed driver seat fan motor assembly?
Im looking for the correct fan assembly part number?
Can i just disconnect the battery to deactivate the driver side airbag from going off?
And any additional info that maybe helpful when doing the fan motor swap. Thanks for your help up front.
you must unplug the battery before disconnecting any connectors/harnesses especially for the srs system (air bag)
hope this helps
part should be close to 50 bucks
Sure it is the motor, might check the fan connector and fuses, passenger kick panel #16, 5 amp, and in the trunk wheel well #26, 30amp. Don't remember hearing of fan failure.
thanks however when i do a search on the part number (19n550) i get a number different numbers ( 6h6z-19n550-aa) or (4w4z-19n550-ba) which one is the correct part number for driver side seat?
fuses are all good.... i turn on the seat cool or seat heat stays lit for 2-5 seconds then goes out. the fan never turns on. Passenger side works fine.
which one? all are offered by the same vendor.....
FORD 4W4Z-19N550-BA BLOWER ASY - VENT AI (Package of 1) $284.00
FORD 8A5Z-19N550-C BLOWER ASY - VENT AI (Package of 1) $140.00
FORD 6H6Z-19N550-AA BLOWER ASY - VENT AI (Package of 1) $43.00
