krunk_muzik
So I decided to check my spark plugs today, after changing them about a year and a half ago, and I was surprised to see what I found (I'll explain later). I was using Bosh Platinum +4 spark plugs (regret using those). The LS runs good, no check engine light, no codes of whatsoever. But when idle, I can feel a light shake/vibration. It's not a very noticeable shake, you can only feel it if you really pay close attention to it. There's also no "blue" smoke coming out of the exhaust that would indicate burning oil. When I go up a hill, the car seems to struggle just a bit to accelerate, sort of like a jerk/shake. So that lead me to check my coils/spark plugs. All coils are good. But when I took my spark plugs out, i found oil on the spark plug threads. Not on the ceramic part, which would indicate a bad valve cover gasket. BUT, there were 2 plugs that had some oil on the ceramic along with rust-like residue on it. So I'm wondering what could cause oil to leak onto the spark plug threads? I posted some pictures so you guys can see what I'm talking about. I'm considering replacing my valve cover gasket...
