My cd player says "slots full" but there aren't any cd's in it at all. It would seem that it is some sensor that is throwing it off. Any ideas or suggestions?![]()
What generation is your LS? I have a gen II six disc that I removed from my 04 when I put an AVIC in. I'll probably never have a use for it...
I'm not trying to swoop in and steal this guys deal or anything but do you know if that 6 disk can replace the gen I tape player with remote 6 disk?
Even the tape player has its tape sticking issue... Mine had a tape jammed in it when I bought it. Took 20 minutes to forkout that Smokey Robinson's greatest hits.
Never tried a tape after that but the disk changer seems to work great. I'm just not sure if it would interface with everything (changer could go I guess).
I'm sure that it could be done, but I think that in this case (trying to fit a gen II radio to a gen I car) you would be better off to go aftermarket.
What do you guys mean by they look cheap??
The best players are aftermarket. Unless you mean the plastic kit that has to be installed, you can always get a silver trim piece from one that had nav and an aftermarket double will pop right in.
No i wouldint install a single din unit unless i needed to do a high end setup with an eq below it. But a properly installed unit does not look cheap. And you can even find ones that match the color of the nav unit.
