how to remove degas bottle?
Hernandez
Mexico
i have a leak i would like to fix it, i saw the most common is degas bottle crack..
but how do i remove it, does somebody has step by step?
What year are ya talking about? Here is a quick rundown for the 03-06
1. Remove the windshield wiper arms( 2-13mm nuts under the rubber gromets)
2. Remove the plastic piece under the wiper arms, this is done by pulling out about 8 plastic push pins and it will pull off and also the unhook the wiper fluid line when removing the plastic part.
3. Remove the stablizer arm , it is held on with 7-13mm bolts and then lifts off.
4. Remove 2-10mm bolts from the degas bottle and the small upper hose along with the heater bleed hose that locates to the bottle.
5. Unclamp the lower degas bottle hose from the line that is located on the firewall about 10inches left of the mastercylinder.
6. Pull the bottle out and replace the factory clamp on the lower hose with a new one to make it easier when putting the bottle back in.
It not that hard to do at all, I have done 4 different ones and it takes me about 30mins.
