Gunther1000
My Sunroof has was not used much by the orig. owner and the car did sit for several months before I resuced her.
Upon my first attempt to open it it would only move a few inches back then stop. Press button again, moves 1/8 inch back and so on untill it found a "maximum" 3/4 open sticking point. So I fished around with a rag and some
WD-40 to get it as clean as I could and after some love it seems to open
and close with ease however, The tilt function takes several hits to get it up.
In doing this The motor never seemed to struggle or strain, just stop.
Seemed like a switch issue but after pulling the switch cover and unplugging and replugging it, no change there (no surprise).
I think I can rule out the switch due to it now opening and closing fine after cleaning and oiling.
I have tried several times to program my garage door opener to the home link
and no matter what slight variation I use it will not work.
Currently using these methods:
1.Hold two outter buttons untill fast flash. Release both then press right most
button while holding opener button at the same time untill flashing slows or stops.
2. same as above but not releasing the right most button after step one and holding the remote door opener 3-5 inches away untill slow flash stops.
NOTHING.
Is there a known suspect in this or should I give up?
I hate giving up on something mechanical but with electronics involved sometimes A man has to know when he is beat.
Any help?
Thanks
NOTHING.
Any help?
Thanks
