Alright, I haven't really dug into it yet but I'm lookin to hear if anyone else has had similar issues, hopefully giving me a direction to take this.
Tried to start my LS friday after it sat for a couple weeks in the garage. It fired up and was making a pretty nasty sound. Sort of a knocking, but the radio was on so I couldn't really tell what sort of knock I was getting. So I shut it off really quick. Turned off the radio and tried to start it again. Engine turns over, but does not fire. It seems as if there is zero ignition or fuel delivery. However, I've not checked either yet. I'm just crossing my fingers that someone will say something like "Oh yeah, I had that exact same thing happen and it turned out to be my crank position sensor". I'll be digging into it this week when I have some time.
Unless someone speaks up here, the first spots I'll be checking will be:
-Codes (my reader doesn't work with it- have to get one from autozone)
-Fuel
-Spark
-verify timing components are all in order (chains in tact, cams moving)
-Check valves, ensure none are visibly damaged
-Check spark plugs for damage
The biggest worry here for me is the noise it made when it initially started- it didn't sound very healthy. Had it just decided to crank but not fire I'd be a lost more at ease about the situation.
-Fuel
-Spark
