dccv service and coolant bleed?
Gunther1000
Brentwood
If I want to remove me DCCV to clean the plungers will I have to
purge the air out of the coolant system or does it not effect it enough?
I tried the search but of course the answer was not found...
:confused:
You will have to recover or replace the coolant lost when you disconnect the hoses, and then you will have to bleed the air out. Bleeding is not a big deal at all compared to removing and cleaning the DCCV.
Cool, Thanks.
I figured it would be needed but hoped there was a possibility I could get off
easy.
This is going to be a busy cam tensioner/Dccv filled weekend for me.
I ran some Prestone cooling system cleaner through my system as the DCCV seemed to be malfunctioning on occasion. That was about 6 weeks ago and I have no DCCV symptoms since. You might want to try that first. The DCCV is difficult to pull out and work on in the limited space around it.
