myfirstlincoln
So I pulled the coil covers off today and all was going well until I noticed one of my coils had a little adhesive pad on top...:shifty:
From what I can gather, the idiot broke the bolt that holds the coil down and is basically keeping the coil in by pinching it under the coil cover (hence the adhesive pad on top of the coil.) I can see the bolt (head snapped off) but I can't get anything on there to get it out. I'm assuming I cannot simply drill it out with the cover still on the car correct? If I drill out the bolt would all the shavings end up in the engine or don't those bolt holes go down into the head? I would need to remove the entire valve cover?
Also, all my spark plug wells looked pretty damn clean except the drivers side second from the front of the car. It had a good amount of oil in it? I believe VCGs were done about a year ago under the Ford bulletin for 03's. Any ideas on why only 1 well would have oil?
