Dukernc
Using search and reading thru all the post I can’t seem to find an answer to my dilemma. I think it may be a clock spring but, just not sure Ok, here’s the situation.. you be the judge. Thanks in advance! So, my cruise control seems to come on if I play with the on/off switch, the light comes on in the dash and only the set button works to engage it. I can only turn off/stop the cruise by tapping the brake. I must do the exact same thing to use the cruise again. None of the other cruise control buttons work. Next, I sometimes get these messages via the diagnostics when the car first starts up. Left rear tail light out.. Right rear tail light out. The lights are all physically fine. Also, some times the alarm will sound off after I use the fob to get inside and try to start the car. I have to lock / unlock the car a couple of times via the fob before it will start without the alarm going off?? All of these “bugs” are intermitting. Clock spring?? Suggestions? Thoughts? Thanks again!
Regards,
Dukernc
Regards,
Dukernc
