upnorthLS
Thanks for the in-put on my start up issue. I forgot to mention the car has just hit 60,000 miles. When this happened, the rpm's went to 3000 and the etc flashed and fail safe was flashing. The cel did not flash. After shutting it down immediatly and letting is sit for a minute and restarting it, everything was normal? Do you guys still think it could be #4 coil acting up as it runs fine otherwise. I've been reading lots of the older posts and it looks like #4 is a common problem and can cause numerous issues. Maybe I should just try and swap 1 and 4 and see. It's just weird and so far has only happened twice. Thanks again for the help. There seems to be way more knowledge in this site than at any stealerships!
