Need help with UCA asap
if your replacing the arm anyways, just cut it off for now, and beat the :q:q:q:q our of it while it is on the ground, that way you can get a bigger swing with a 40 mallet
Use a gas torch, oxy-acetylne and heat it up big time. Make the whole pinch area glowing red.
Then smack the hell out of it.
Thanks guys, got it off yesterday but didn't get a chance to post because I had to run to work. Thanks for the help.
Well how the heck did you finally get it off? This thread so far is like blue balls ended by a premature ejaculation.
